How do I show a window on 'all relevant stories'
Sqeet
Hi
I have an lower ground story and an upper ground story (750mm higher) creating a window (with a sill higher than 751) on the lower ground story doesnt' show on the lower ground floor even though it was created on the lower ground floor and the wall it is penetrating is on the lower ground floor. I believe that I need to show it on 'all relevant stories but can't work out how to do this.
Thanks
3 REPLIES 3
Hi @Sqeet,
In these cases I create only one ground story with two slabs (no lower or upper stories).
But ok you can keep your 2 stories while creating only 1 wall penetrating them then you can set this wall to be shown in all relevant stories.
That let's you create 1 or 2 windows in this wall while you control which window/s to show in the floor plan  via FPCP or (Floor Plan Cut Plane) dialouge from Document menu.
AC 28 INT 5200/WIN 11
Thanks Mahmoud,
I reverted to your first solution- one storey with two slab heights and that works a treat
Thanks
Thanks @Sqeet, you're welcome.
