How do I use the mesh 3d v2 object in archicad 14?
I just downloaded it but i can't make sense of it. I don't even know how to install it. Does it have a tutorial?
http://archicad-talk.graphisoft.com/viewtopic.php?p=141715#141715
Found this in the comments of the part you downloaded.
As for installing it, you should be able to load it like any other library part, I would imagine. I would place it in your library according to how you handle your libraries and select that library to load when you start a project or open the library manager under /files/libraries and objects and direct it to where you have the mesh object stored. If you need more go to /help and open AC Help or the AC reference guide. I could explain it but there should be pictures and everything already in those guides.
There is an even newer version (V3) with some useful extra settings here -
http://archicad-talk.graphisoft.com/viewtopic.php?p=172715
Instructions and installation are the same as before.
