How do I work with hotlinks?
LeeJaeYoung
I need to connect a hotlink like this.
I know it's wrong.
How do I connect a hotlink to solve this?
AC27 on window 11
31 REPLIES 31
uint.mod hotlink -> building A.pln
building A.pln hotlink -> all.pln
I use adjust elements to slab in building A.pln
but in All.pln
Is this a bug?
Or is this also the normal working of Archicad?
AC27 on window 11
We need your opinion.
Is there a way to make the door appear in to from ... - Graphisoft Community
I will delete this sentence.
AC27 on window 11
@LeeJaeYoung ,
There is no need to post here for an answer to another post.
I have seen that post and I don't really have an answer for you - somebody else might.
It's important to me, so I asked myself.
sorry. (Unlike the others...)
I like your answer.
Can you help me understand my English, which is short?
AC27 on window 11
As you can see, your other question is getting some answers.
Sometimes it may take a little while.
If you don't get a response in a day or two, just reply to that post yourself to ask if anyone has any ideas.
I can't help with your English, but if you try to explain as clearly as possible and post images of what you need (as you are doing), then all we can do is try to interpret what you want as best as we can.
It is a little difficult with images as they can't be translated.
Is there anyone else in Korea (I believe you are from) that you can buddy up with for help?
Do you have a local Archicad support office that can help or maybe put you in contact with other users in your area?
Speaking with others in your native language may be a little easier for you.
But by all means, keep posting here.
You are understanding English much better than I can understand Korean.
I know you use Google Translate, so keep it up and good on you for persisting with Archicad and this English forum.
Hi @LeeJaeYoung ,
I think you are going to need to share some PLNs to understand what's going on here.
There are a number of different reasons why the slab to wall junctions are not working correctly, and it's easier to have a look at the original file to understand why.
Are the walls, and top and bottom slab all in the same hotlink, or separate hotlink?
Did you potentially change the settings of the wall composite in the hotlink and then update the hotlink?
In terms of how to structure the hotlink nesting, again I think I'd need to see some PLNs.
Sorry I can't be of more use, this seems to be a quite an in depth project setup issue.
I've decided no.
Archie was not made with multiplayer in mind.
There should be an overlap option for each hotlink, but there was no way to do it.
thank you so much.. ^^
AC27 on window 11
I heard rumors that all Archicad employees in Korea are changing jobs. And I heard that they only sold them to other companies. Archicad Cafe has been out of business for a long time.
I don't know why, but I know that the companies around me that started archi gave up and switched to revit. Even if I say I like Aki, I try not to go to Aki no matter what happened. And Archicad gdls are not developed in Korean. I got the 16 version and tried it, but I have to fix everything such as windows and door stamps to use it. I wonder what they have made so far. I want to work with Aki, but companies don't want to.
Oh! I asked the Korean branch of Archicad what it was about gdl and they said they couldn't tell me. It must have been about 8 years ago. So I didn't try to learn Archicad. How did I end up studying hard?
Oh! Are you an Archicad employee?
And I don't know how to find my unanswered question? ^^
Please contact us when you come to Korea. When I'm in Korea, we drink soju together. ^^
Please reply if you read
It's something that needs to be deleted... ^^
AC27 on window 11
No I am not a Graphisoft employee.
Just an Archicad user like yourself and moderator of this forum because as you can tell I like to try to help where I can.
But I don't have answers for everything and so I may not reply to some posts.
I have just found this article that talks about Hotlinked Modules. It may be helpful in this thread:
https://community.graphisoft.com/t5/Project-Management-articles/Hotlinked-Modules/ta-p/303819
