How do you create a horizontal soffit
Hi guys
Is there any way in archicad to create a horizontal soffit (standard in uk) for a roof?
Thanks
Adam
8 Replies 8
apologies archicad 15
A slab?
thanks steve
is that the standard way people do it - i was hoping their was a setting in roof creation thing
Thanks steve
tried it out and yes it works
thanks very much
Yes, that's the way I do it at least. Slabs, beams, columns and walls can be used for all types of building elements.
Hello Steven,
Just wondering.
Have you tried making the entire eave soffit assembly
one complex profile ?
I made a library part to make eave soffits
way before complex profiles were available and
haven't needed to experiment with complex profiles
for this purpose.
Thanks,
Peter Devlin
David Maudlin
This is the way I handle soffits, and is part of my template. Make the depth and height small, with stretch lines behind the fascia board, and it will work in many situations.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Yes I have, when the overhangs are the same. When you have different rake/eave overhangs and you try to intersect them, it does not come out well.
