2018-11-12 01:58 PM
2018-11-12 02:26 PM
joa101501 wrote:You can search the internet for formats rather than .gsm (Objects), like .3DS and .OBJ, import them and save as objects. This will give you a broader range of options. These objects won't be parametric, but will represent real furniture.
Also, I would like to know where an interior designer get his/her high quality furniture for ARCHICAD. We know that some of the built-in objects in ARCHICAD are "too generic" and ugly for production use.
2018-11-12 03:15 PM
David wrote:I have tried this already but the results are not optimal. The result is always an increase of the PLN file size. It also slows down the drawing to a crawl. Also, the resulting model ended it a lot of triangulation.
David wrote:Sorry about that.
2018-11-12 04:26 PM
2018-11-13 02:28 PM
joa101501 wrote:After importing the models, convert them to Morph. Then use the Morph command Modify Segmentation > Fewer Segments to decrease the number of polygons. If you download and install the Goodie PolygonCount you can get a reading on the number of polygons as you modify the model. When done, save the Morph as an Object to place multiple copies.
2018-11-17 01:11 PM
David wrote:Thanks for the patience Mr. David. I never knew about this workaround. This is a great piece of life-saver advice. Now I can go back to my previous workflow without worrying about hiccups. ARCHICAD community is very generous!
2018-11-17 01:23 PM
Erwin wrote:I've been using hotlinked modules for quite some time on all our projects, but I never thought of using this feature to streamline the project by dividing it modularly by phases. It makes more sense now that you mentioned it.
If your project is not strictly interion design, you could consider hotlinking the 'technical / building'-model to a presentation file. In this separate file you add the furniture and such for renders. This keeps your technical drawings clean and the file size down for that file.
Erwin wrote:This is what I've been looking for to give me a headstart on CineRender.
This might be an interesting read to scratch the surface of what can be achieved with cinerender and some post processing:https://www.graphisoft.com/users/bim-case-studies/svetlana-kravchenko-archicad-revisiting.html
