2008-05-09 03:05 AM
2008-05-09 03:20 AM
2008-05-09 03:29 AM
2008-05-09 05:53 AM
Hunter wrote:That would be to Project North, as it is relative to this that you want to measure your angle. Archicad measures angles anti-clockwise, we want to go clockwise, which is the reason for the MINUS after your angle input.
In researching the topic, I saw your method before I posted.
You say to Constrain cursor to North, but is that where project north is, or is it 'on the Horizon' as graphisoft puts it (to the right on the x axis)?
I want to be able to set my project north (in the more sun dialog), then enter the cooridnates as degrees, minutes, seconds relative to that. I figured this would be a pretty simple process in AC11?
Hunter.
2008-05-10 02:32 AM
2008-05-11 10:17 PM
