How to adjust a curtain walls upper frame to match roof?
How to make the curtain wall's upper mullion along the roof, (cut the ceiling is slope, and the curtain wall is circle)
anybody help
best
4 REPLIES 4
MrC
have you tried SEO or trim commands?
ILIFFE ARCHITECTURAL
BRITISH COLUMBIA
macbook pro 2.7 GHz Intel Core i7 8 GB 1600 MHz DDR3 NVIDIA GeForce GT 650M 1024 MB
AC 21 USA (latest build)
oh, yes, I SOE trim totally not work, and the trim under element connection cannot work as well......
so.... so sad
no body knows the solution?
David Maudlin
imxxx:
You will want to edit the Curtain Wall Boundary, one guide to do this is here: Edit Curtain Wall Boundary, there are others in the Help files, but due to the curve in plan, editing in the 3D Window may be best.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
