Llian
How to adjust the line/bubbles size ?
I want to add revision bubble in a tabloid sheet size drawing but the current preset seems big. is there a way to resize ?
Lilian Seow LEED AP | cSBA | CAPM | PMP
AC 29 USA FULL | Windows 11 Enterprise i5 3.10GHz | Archicad-user since 1994!
5 Replies 5
David Maudlin
Llian:
If this is the "Bubble" line type, to change its scale, open Line Types..., select the Bubble line, and change its Dash size. You can also duplicate the Bubble line (use the New... button) to create a Bubble line type of a different size.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Stress Co_
Llian:
I like using a "closed end" spline with a bubble line type.
Seems more versatile and it's how I would have drafted by hand. Just remember, it matters which direction you create the spline (for the bubbles to have the correct orientation).
Marc Corney, Architect
Red Canoe Architecture, P. A.
Stress wrote:
Llian:
^ This
Llian
Stress wrote:
Llian:
Thanks Stress......the spline definitely seems to be the only tool that allows for a 'closed' loop!
Aren't there some "redline cloud" objects in the standard library.
Rectangular and circular.
