LeeJaeYoung
How to build a sloping wall like that?
1. elevation
2. plan
AC27 on window 11
7 Replies 7
Patrick M
Ace
something like this:
Patrick M
Ace
you can get the same opening on some windows, or you can just model them as 2 separeate windows; one for the unit, the other for the wall hole
LeeJaeYoung
Thank you for your interest.
I think it's a little different.
The structure was not changed, but the finishing wall was changed.
1. Don’t I need to separate the wall for this type of wall?
2. I think the key is how to connect the finished wall to the inwardly slanted lower part.
AC27 on window 11
LeeJaeYoung
Shouldn’t the finished wall and the structural wall be separated?
How should I build the wall?
The walls from the left and right and the walls from the top and bottom must be connected like this.
What should I use for the walls at the top and bottom to connect them like that?
AC27 on window 11
LeeJaeYoung
All I know is how to morph something.
Only the upper and lower walls are made into morphs, the rest are walls.
The overlapping part of the diagonal line was removed by SOEing the wall.
But is it okay to leave the wall created with morph as is?
Do I need to add SOE to any wall?
AC27 on window 11
Patrick M
Ace
the shape you have shown as a morph may need to be broken up, and used as operators on the wall finish using solid element operations.
LeeJaeYoung
Can you please explain a little longer?
1. I don’t understand the meaning of broken up.
2.I would like to know what the purpose of using solid element operations is.
Thank you for your interest.^^
AC27 on window 11
