How to change a measure ore move and object.
Hi.
I have got a file from someone else, and some of the settings are different than usual. When I want to change a measure i start to do the change and normally i start to type in the difference. But now it does not snap to the direction, but always moves in one direction. Is there a way to change this? If i work in another file it works normaly, so i cant change the way I work couse then it works diffrently in another file with other settings.
Thanks.
0 Replies 0
