How to create multi stories building?
Hello
I would like to know how can i create multi stories building
example i like to create a building with 100 stories and coping these stories one by one from ground floor to 100 floors takes much time?
Is there any way to make a walls windows doors only in ground floor
and these(walls windows doors) automatically to repeat in every floors from ground floor to 100 floors?
Thank You
Look at hot linked modules in the reference guide and interactive training guides.
Scott
I have moved this post and deleted the poll as it is not a wish for a new feature.
As sboydturner said look at hotlink modules.
Create the module for what you want to model and place an instance of it on each floor.
Then if you edit the original module all floors will adjust at the same time.
Or you can break the hotlink if you want to adjust an individual floor separately to the original module.
