How to create thickness on roof (fascia board for example)
can i custom thickness on roof> for example 400mm thick on fascia board.
3 Replies 3
Go to roof default settings and change the Cut Fill under Structure.
ok. but the max thickness it 380. if let say i want 500 mm. wher to put tat under the cut fill ? i custom my own i mean.
If you make a custom composite structure, than you have to change the size of the layers from that structure, otherwise you can put a simple fill and change the size to as much as you want to. The default set is roof, conversion. Just change it and you will see what i'm talking about.
