How to customise your curtain wall in Archicad?
Do you feel limited by your current Curtain Wall skills?
Here are some key settings to unlock new design possibilities and create stunning, customized facades in Archicad. Watch the video for the detailed steps!
Step 1: Create a Custom Panel
One of the most powerful ways to customize a Curtain Wall is by creating your own panel. You can use any 3D object as a base. For example:
  • In our example we used a profile sheet object.
  • Save this object as a Curtain Wall panel under File > Libraries and Objects > Save Selection as
Step 2: Set Up Your Curtain Wall Scheme
  • Begin by configuring the Curtain Wall's height and position.
  • In the Scheme tab, click the "X" to start with a clean pattern. This provides a blank canvas for your custom design.
  • Since you know the exact sizes for your panels, use "Fixed Sizes" for both columns and rows.
  • Define the edges as divisions to ensure the panels remain separate when duplicating.
  • Add all your panels and adjust their sizes to form the desired composition.
  • To create a shifting effect or a single large panel, select specific divisions and set them to "Merge Panels."
  • Add transom frames to enhance the design.
Step 3: Configure Panels and Frames
  • Set your solid panels as Distinct.
  • Assign your custom panel to one of the solid types.
  • Adjust the rotation angle to align with your design vision (e.g., 0° for vertical alignment, or rotate for diagonal or varied textures).
  • Define Glass Panels as Main Panels, which will typically fill the remaining slots.
  • Don’t forget to match the boundary frames and transom frames:
    • Use the same type, size, and surface materials to maintain a cohesive appearance.
Adding an Entrance
  • On the ground floor, switch to Edit Mode to customize the entrance.
  • Remove the existing frame to fit the new panel properly.
  • Select the panel. and replace it with a custom element like a revolving door.
Want to dive deeper? Check out the Learn Archicad! program!
Browse more articles
Back to articles
