How to create a sleek, minimalist look for floor plans in Archicad
Want to give your floor plans a clean, modern look? With Archicad's Graphic Overrides, you can easily customize the appearance of your elements based on certain rules.
Follow these steps to achieve a minimalist design for your floor plans!
Create a Graphic Override Combination
Open Graphic Overrides
  • Navigate to the Graphic Overrides Combination panel (Document > Graphic Overrides > Graphic Overrides Combination)
  • On the left, you'll see combinations—create a new one.
  • On the right, add three rules:
    • For general elements, like objects
    • For slab fills
    • For cut elements
Set Rule Priority
  • The top rule takes priority, so place the most specific rule at the top and the most generic at the bottom.
Define the Rules
General Elements:
  • Criteria: Use the default (Element types as All types).
  • Line Color: Set to medium light gray.
Slab Fills:
  • Element Type: Slabs.
  • Fill Foreground Color: Set to the lightest gray.
  • Cover Fill Option: Turn on.
Cut Elements:
  • Criteria: Wall, column, door, window, and curtain wall.
  • Line: Set to dark gray.
  • Fill Foreground: Set to gray.
Apply the Graphic Override
  • Apply the graphic override to your views.
  • You can customize your design by changing the pen and fill colors or adding extra rules.
Want to dive deeper? Check out the Learn Archicad! program!
Browse more articles
Back to articles
