‎2010-12-04
04:21 PM
‎2023-05-23
04:46 PM
Rubia Torres
‎2010-12-04 11:45 PM
‎2010-12-04 11:55 PM
‎2010-12-05 12:31 AM
WhiteMan wrote:Try using OBJECTiVE to model the objects and to do the cutting. Referring to the attached image:
I want to cut the object showed in the picture, that way that I get the part inside the exterior walls. I've tried SEO but it doesn't work (probably because it's not realy upside or downside cut, but vertical)
Any tips?
‎2010-12-05 01:29 AM
‎2010-12-05 02:02 AM
Dwight wrote:Could you please give some more explenation about this technique?
SEO is the answer, but extrusion up from a special slab is the solution.
‎2010-12-05 02:13 AM
‎2010-12-05 04:10 AM
WhiteMan wrote:I'm not sure if this is what Dwight means, but it's a simple intersection with profiled walls as the targets and a slab as the operator.Dwight wrote:Could you please give some more explenation about this technique?
‎2010-12-05 07:52 AM
‎2010-12-06 08:28 PM
