How to hide lines (borders) or merge meshes?
Hi guys, how do I hide the borders of the mesh objects?
Dashed elements in the picture make up a paths system. I would like to hide the intersecting lines (those "inside" the walkway).
If it's not possible to literally hide those borders, how can I join the meshes to make it a one big shape? Meshes are 0cm thick, so they are basically 2D.
David Maudlin
You will need to do it one by one:
Select one Mesh, click on its edge to bring up the Pet Palette, select the Add to Polygon option (third from top right), hold down the Spacebar to bring up the Magic Wand, click on the edge of another Mesh. The second Mesh will still be there, so may need to be deleted.
If the Meshes were Fills, you could use the Fill Consolidation command.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
It worked, thank you David.
