How to insert a scanned image 2 scale in drawing.
Hello, I would appreciate it if someone could tell me please, I have a floorplan image of a boat and because Im not very good at working out the radious of each curve etc, I thought If I could scan the floorplan & insert it into archicad at the scale I need and then utilise the image to trace with wall tool.
If anyone knows HOW I can do that I will give u the HUGEST cyber hug!!!
Have an AWESOME day/night!!!!
7 Replies 7
Chazz
Drag your image file into your floor plan window (or use the figure tool). Then use the Resize tool with the graphical method selected. NOTE: You must have a known dimension in your image file and use it with the Resize tool. HTH.
Nattering nabob of negativism
THANX CHAZZ!!! Your a legend!!! I havent tried it yet but will do. At the risk of sounding dumb.....when you say drag, do you mean copy & paste the image???
Link
He means drag and drop. If you're on a PC, you can drag it and hover over AC on your taskbar until AC opens, then drop it into the floor plan. This will bring it in as a Figure.
I would be more inclined to bring it in as a drawing, as it gives basically the same resizing options, but can also keep a live link back to the original. This way you can replace the original with any updates and it will update in AC.
To use this method simply try placing a drawing with the drawing tool, and choose the image when prompted. Once placed you can scale it either using the drawing's settings or via the Resize command.
Link.
thanx SO much Link!!!!I really appreciate it!!!
Oh meant to say, HOWdo I bring it in as a drawing if its a scanned image please?
Link
Just slow down a bit and read the instructions.
Use the drawing tool in your tool box. Click on the floor plan and when prompted, Link To your scanned image. Make sure the Files of Type at the bottom is set to All Images or All Available Types.
Play around with it.
Link.
Sorry, I just reread it & understand what you were saying. Thank you for your patience & understanding, I really appreciate it.Have an AWESOME day/night!!!
