rob2218
How to make a custom linetype? with "ltrs" in between dashes
see attached.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
5 Replies 5
These are created as symbol line types. To do this you draw the dashed parts including the letters (like the vector fonts of old) using the line tool. Then copy/paste them into the line type set up dialog. This is different from the line tool settings dialog and is found under Options > Attributes > Linetypes (or something like that - it should be at the top of the options menu).
Katalin Takacs
Graphisoft Alumni
Graphisoft Alumni
In this ArchiCAD Wiki article you can read more about custom Line Types: http://archicadwiki.com/LineTypes
Katalin Takacs
rob2218
thank you Katalin for your information.
I'll have to begin to look up more of my questions on that Archiwiki site.
Once again, much thanks.
RR
i>u
Edgewater, FL!
SOFTWARE VERSION:
One lesson learned. Make sure the the geometrical center of all lines that will construct your new linetype is in the center of your line. Otherwise your line will be slightly off center. Unfortunatelly some of the standard line types with letters are off center. It is clearly evident when you look at he corners and the lines just don't join properly.
rob2218
thank you ......for everything folks.
i>u
Edgewater, FL!
SOFTWARE VERSION:
