How to make complex profiles cleanup up at corners?
rob2218
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
11 REPLIES 11
rob2218
Richard,
Come on...this isn't physically impossible.
As a matter of fact GS even has a help guide on this verydame issue, but as all GS help guides, they read like stereo manuals and not really a step-by-step easy to follow guide.
No matter, was able to get best I could w a morph object st the corners that take on the shape I need to make the sloped and the flat intersections work in 3D.
It's not impossible, done all the time by mediocre carpenters.
Richard wrote:
Rob,
You seem quite upset that ArchiCAD can't easily draw something that defies basic geometry, and is technically unbuildable as you're trying to do it. You have several options:
1) Give the roof a square-cut end, rather than a plumb cut. This will let you wrap the profile exactly.
2) Use a slightly stretched profile for the vertical crown molding height, which will match the sloped crown's plumb height. Not perfect, but about the best you can do with a vertical fascia.
3) Move to a non-Cartesian universe.
i>u
Edgewater, FL!
SOFTWARE VERSION:
rob2218 wrote:
Richard,
While your "can do" attitude is admirable, I assure you that the hypotenuse of a right triangle is never going to be the same length as either of the legs of that same triangle.
Richard
AC26 (since AC6.0), Win10
