2017-05-29 09:13 PM
2017-05-31 05:17 AM
Richard wrote:
Rob,
You seem quite upset that ArchiCAD can't easily draw something that defies basic geometry, and is technically unbuildable as you're trying to do it. You have several options:
1) Give the roof a square-cut end, rather than a plumb cut. This will let you wrap the profile exactly.
2) Use a slightly stretched profile for the vertical crown molding height, which will match the sloped crown's plumb height. Not perfect, but about the best you can do with a vertical fascia.
3) Move to a non-Cartesian universe.
2017-05-31 05:27 AM
rob2218 wrote:While your "can do" attitude is admirable, I assure you that the hypotenuse of a right triangle is never going to be the same length as either of the legs of that same triangle.
Richard,
Come on...this isn't physically impossible.
