How to model a Cycling Track
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2019-07-09 08:19 PM
Is there a way to model a cycling track using ArchiCAD native tools?
I would like to have a 150mm thick concrete for the track.
The issue is the straight and the curve are at different slopes (see attached image).
I tried using a complex profile but, it would not connect seamlessly.
Any suggestions?
Construction Modeler
BIMSOLL
i7-4930K Dual 3.4 GHz 32 GB RAM
NVidia Quadro K4000
SSD+HDD, Win7-64 ENG
AC25 (64-bit, latest build)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-07-10 09:59 AM
I would try with a complex profile associated with the beam tool
Like this :
As you can see I tested the same profile with the guardrail tool but it did not close properly
It possible to use the wall tool as well
Archicad Designer and Teacher
Archicad 15 to 28 FRA FULL
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-07-10 11:14 AM
I may not have been clear on the cycle track design.
The track has two different slopes (as shown in the previous image), the 'straight' part of the track is 5.5 degrees and the curve has the 28 degree slope. The small 3D image is where the connection of the two slopes, this is where I am having the issue (see the full 3D image). As you can see, I did initially try the complex profile. I am hoping this could be solved with ArchiCAD native tools but, maybe I am asking too much?
BIMSOLL
NVidia Quadro K4000
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-07-10 11:46 AM
If you need a illustration about shell tool :
Here
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-07-10 12:41 PM
Thanks for your solution. I will give a try!!
BIMSOLL
NVidia Quadro K4000
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-07-10 09:48 PM
Are you going to generate a set of Construction Documents for a Cycling Track or just model a geometric representation of it ?
https://www.velotrack.de/index.php/Velotrack.html
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-07-11 11:53 PM
Thanks for the link. This track will be outdoors.
The cycling track will be part of a Sporting Pavilion set. I wanted to model it to place it on the site to get the site levels correct (especially at the curve where slope is steeper) as well as have the sections correct and of course have it for 3D perspective views. It's more for construction layout but will be very useful for 3D coordination.
Would be nice to give the contractor an estimate of the volume of concrete as well.
BIMSOLL
NVidia Quadro K4000
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-07-24 03:24 PM
I was asked to put the 'slope' on the curve and not have it on the 'straight section'.
I am trying it with the Mesh Tool, as I can't see an ArchiCAD tool giving me a single sweep and then allow me to lower one end to the lower 'strait section'.
Do you think it is the right way?
BIMSOLL
NVidia Quadro K4000
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-07-24 07:02 PM
I do not think mesh is the best way to do this but there is no wrong way
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-07-24 11:56 PM
