Aussie John -
Thank you, Thank you!!!!
This worked! It did exactly what I was looking for including providing me with a volume calculation. Not only did it work, it was FAST - about 15min. I would guess after I figured out how to do it. Next time around will be very easy.
The only hitch I ran into was the first couple of times through the SEO operation, the largest portion of the site was not cutting as it should - I then split my mesh into smaller pieces and it worked fine.
Thanks again!!!
krause
