How to quickly transfer dimension marker between windows
If 2 windows are already configured, with different settings and parameters, how can I transfer quickly the dimension marker settings only from one window to the other, thus maintaining all the other parameters ?
1 REPLY 1
Good point for the wishlist....here is my "partly" workaround:
I would first change the marker in infobox - then I would select the doors/windows that need change and the last selected object would be the "correct one". So the properties showed when Ctrl+t hit shows the last selected object - I would change the markers' parameters a bit (unfortunately all of them) hit ok and then on next Ctrl+T I would change the settings back.
Regards,
Piotr Dobrowolski
