'Lock' Distance Between Multiple Walls
Hi there, I'm attempting to replicate a particular documentation method I used in my past life as a Revit user.
I recognise each program has its own unique philosophies and methodologies, so happy to be told to adjust my documentation approach.
Question: Is there a way to lock the distance between walls? I am modelling an existing structure, and in Revit would run a dimension string between all the parallel walls and then 'lock' those dimension so that the distance-relationship between those walls could not be altered.
Operating system used: Windows ArchiCAD 23
AC27 INT 3001
Windows 11 Pro 10.0.26100 Build 26100
MSI Vector 16 HX AI A2XWHG
32GB RAM | Intel Core Ultra 9 275HX, 2700 Mhz, 24 Core(s), 24 Logical Processor(s)
1 Solution
There is no relationship like that in Archicad.
But you can 'Group' elements and then as long as grouping is enabled, they will move together.
Go to post
3 Replies 3
thanks Barry 🙂
AC27 INT 3001
Lingwisyer
Guru
Do note though that grouping walls like this and moving them will not stretch their connections with other walls.
