Archicad design tools: Workflows, element connections, modeling tips
'Lock' Distance Between Multiple Walls
Hi there, I'm attempting to replicate a particular documentation method I used in my past life as a Revit user.
I recognise each program has its own unique philosophies and methodologies, so happy to be told to adjust my documentation approach.
Question: Is there a way to lock the distance between walls? I am modelling an existing structure, and in Revit would run a dimension string between all the parallel walls and then 'lock' those dimension so that the distance-relationship between those walls could not be altered.
Operating system used: Windows ArchiCAD 23
AC27 INT 3001
Windows 11 Pro 10.0.26100 Build 26100
MSI Vector 16 HX AI A2XWHG
32GB RAM | Intel Core Ultra 9 275HX, 2700 Mhz, 24 Core(s), 24 Logical Processor(s)
There is no relationship like that in Archicad.
But you can 'Group' elements and then as long as grouping is enabled, they will move together.
thanks Barry 🙂
AC27 INT 3001
Lingwisyer
Guru
Do note though that grouping walls like this and moving them will not stretch their connections with other walls.
Setup info provided by author
