2 weeks ago - last edited a week ago by Laszlo Nagy
Hi there, I'm attempting to replicate a particular documentation method I used in my past life as a Revit user.
I recognise each program has its own unique philosophies and methodologies, so happy to be told to adjust my documentation approach.
Question: Is there a way to lock the distance between walls? I am modelling an existing structure, and in Revit would run a dimension string between all the parallel walls and then 'lock' those dimension so that the distance-relationship between those walls could not be altered.
Operating system used: Windows ArchiCAD 23
Solved! Go to Solution.
2 weeks ago
There is no relationship like that in Archicad.
But you can 'Group' elements and then as long as grouping is enabled, they will move together.
2 weeks ago
2 weeks ago
thanks Barry 🙂
2 weeks ago
Do note though that grouping walls like this and moving them will not stretch their connections with other walls.
AC22-28 AUS 3001 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win10 | R5 2600 | 16GB | GTX1660 |
