How to remove last dimension point ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
ā2022-02-21 02:13 PM
Hi , How to step back while setting dim points ? Like if I drawing a chained line I can press Backspace button and it will remove last set point.
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2022-02-21 02:17 PM
While you are selecting points for your dimension, you can click on any of those little target points to un-select that point.
If you have already placed the dimension, you can select the nodes (marker) of the dimension and delete them.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2022-02-21 02:18 PM
If you want to remove the dimension point, click on it again and that point will be removed
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
