kosta
How to remove last dimension point ?
Hi , How to step back while setting dim points ? Like if I drawing a chained line I can press Backspace button and it will remove last set point.
2 Solutions
While you are selecting points for your dimension, you can click on any of those little target points to un-select that point.
If you have already placed the dimension, you can select the nodes (marker) of the dimension and delete them.
Go to post
filip
If you want to remove the dimension point, click on it again and that point will be removed
Go to post
filip
