How to scale up a morph with reference poits
Hello, I want to scale up a morph element on a bigger reference object, like Scale/Reference/R in ACAD, please advice how
Thanks
I got it, Reshape S chale
4 REPLIES 4
You can also use the "Box Stretch" command accessible in the Morph's Pet Palette to stretch the Morph geometry in any of the 3 main directions independently.
Hmooslechner
another way: safe it as a GDL - librarypart and scale it then in the Library-Toolset.
Sculptdesign
Morphs will scale in 3D but not 2D.
ArchiCAD 26 Solo - Mac
