How to show finish mat. at wall ends?
Is there a way to have the gyp bd., stucco, or other wall finish material wrap
around the end of the wall?
19 Replies 19
Jonathan wrote:
So, you can make a mod file of any part of a project that is selected and send to whomever for whatever. Is it too complex to explain the basic difference between hotlinked and not hotlinked?
You can think of a MOD file as saving clipboard elements to an external file. So, where you might copy and paste within your own file, you can save-as-MOD and send that to a friend, and they can Merge that... and it is as if they pasted your selection into their project.
A Hotlink can be an MOD, part of a PLN, and more. It is a reference to an external file... sort of like an XREF for AutoCAD if you ever used that, other than it refers to Building Model elements.
Easy save-as-mod and hotlink example: suppose you want the same furniture arrangment of desk, chair, waste basket in every office. You could select those 3 elements, save them as a MOD but allow a hotlink to be made. (Allowing the hotlink means that the 3 elements are DELETED from the active project... and replaced with this link to the external MOD file.) The desk, chair and trash can will now appear as a group with square group nodes in your project. You can copy this group into all of the other offices. They all refer to that single MOD file. If you now decide you want a different model desk or chair, you edit just that MOD file... and the new desk/chair combo appears in all rooms.
A since-the-beginning wish for Hotlinks is that we could edit them in-place (the way AutoCAD users can edit Blocks). But we can't. You have to open a separate instance of ArchiCAD to do that (or close and re-open your project.
Things can get very elaborate, too. Don't want to blow you away, but just to give a hint of where this can go... a PLN can hotlink part of itself back into itself... to make high-rise towers, duplicate and mirror identical hotel rooms, etc. Or, you can create a Publisher set that publishes bits of the building as MOD files... or even publishes 2D details as MOD files for an office detail library.
Used to tell people that everything I know could fit in a thimble and felt good about bragging like that because I was pretty sure it wasn't an exaggeration. Guess I need to rethink this whole idea.
🙂 The nice thing about fitting knowledge in a thimble is that knowledge is infinitely compressible. So, you can actually fit quite a bit. 🙂
Thanks Karl!
It's better, but Still can't get the end face of studs line to match the walls
pen weight?
Frustrating at times to get things just right.... Jon
Karl wrote:
Easy solution. You selected the 'Cased End' wall end object. Simply switching to the 'Wrapped End' cleaned things up.
Karl,
Thank you for the explanation. Very much appriciated!
There is a new jpg. below w/ some more questions if and when you can spare the time.
Thanks again....Jonathan
One more question for now. Can the line shown below be removed by adjusting the material strength?
Jonathan wrote:
Thanks Karl!
pen weight?
Bug in my opinion. A shame to have this behavior in 17... the library part has been out for many years.
See attached screenshot... Weird workaround, but seems to pick up the correct pen. Switch to the Returned End wall end part... and change the number of skins to turn to just 1.
This is the best solution yet, but as you can see on the jpg below that it still is not matching the line all the way, one side or the other has a small
section of outside finish line (the heavier of the two) that is not correct.
Did you see my other posts above? Several questions in there if you have the time.
Thanks again! Jon
Karl wrote:
Jonathan wrote:
Thanks Karl!
pen weight?
David Maudlin
Jonathan:
For the Wall intersection, extend the reference line of the vertical exterior wall and the interior wall to meet. You may also need to edit the Building Materials' Intersection Priority to get the correct result, but you will need to do this for other intersections anyway.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thanks David,
I guess the correct order would be to do the intersection priority first and then
clean up the skins in the building material, priority (weak / strong) settings?
It's a bit of a challenge, but the results are amazing and well worth the effort. I may even decide that it's not necessary to show each top plate, sill plate, block, beam, and continuous member etc., in section anymore. Thirty-seven years of that is enough, maybe?
David wrote:
Jonathan:
David
David Maudlin
Jonathan wrote:
I guess the correct order would be to do the intersection priority first and then clean up the skins in the building material, priority (weak / strong) settings
I would get a few typical intersections (or collisions) set up in plan and section, and then start editing the Building Materials' Intersection Priority to get the desired result, so you have feedback on the consequences of each edit. Then remember to incorporate the changes into your template file.
I've changed my graphic standards from time to time as the software has changed, to better take advantage of the improvements. When I look at an old set of hand drawings, I miss some of the look & feel, but not the work.
David
