How to show plaster finish to the bottom of the staircase soffit slab?
Rajesh Patil
Can anyone help me to show the plaster skin surface to staircase slab soffit?
Rajesh Patil
AC 09-27 | INT | WIN11 64
Dell Inspiron 7591, Core i9, 9880H 2.30GHz, 16.0GB, NVidia GeForce GTX1650, 4.0GB, SSD Internal 500GB, Dell SSD External 250GB
Unfortunately if you want to see it as a skin with thickness in section, you will have to create a roof.
Otherwise you could try duplicating the stair, lowering it slightly, change the structure to plaster and then use Solid Element Operation to subtract the main stair from the duplicate - should work but I have actually tried it.
You will probably want to remove stringers, treads, etc. from the duplicate - leaving just the structure.
Rajesh Patil
Thanx Barry,
I did the same with Beam tool but still its better if ArchiCAD should have inbuilt option for this.
Regards
Rajesh
Rajesh Patil
