archislave
How will Archicad 10 Change our Workflow?
outpostarc wrote:
Between the 2 sneek previews of AC 10 (Spanish & Russian), it looks like it maybe addressing some fundamental issues of the past. I'm looking forward to it. Some of the things that I see are:
Plan ht. cut for walls
Angled and tapered walls
Profile management
Plotmaker integration
Simplified layer management
Merge different walls into single walls
Add footings and trim to walls
Locking elements of some sort
Element Schdule schemes
Walls showing across stories or at plan cut ht.
Elements above plan cut can be dashed
I don't know than what I could glean but again am looking forward to 10!
Based on this information - if true - How will it change our workflow? Sounds quite revolutionary!
Archislave
archicad 26.0 US, M2 Macbook Air
More importantly to me... is this the universal binary that Graphisoft says it is "close to finishing the engineering work of porting ArchiCAD as a native application to this new platform"?
