2009-10-20 04:43 PM
2009-10-25 03:36 PM
2009-10-25 03:52 PM
NStocks wrote:Yes, draw your shapes with something like the slab, fill, etc. I usually draw profile shapes with fills.
Does it matter which tool I use. I tried it with ' Wall ' but it doesn't allow you to change it, Slab works though, should I just use that ?
2009-10-25 05:28 PM
2009-10-25 06:08 PM
NStocks wrote:Using the attached image:
What's the best way to make the separate fills join together ( the round corner and the irregular rectangle ). Also how can I cut the holes in the fill as they are just a Arc created with the ' Arc' tool.
Do you think I should make all the edged more round and parallel to each other i.e top to bottom join intersect if you were to join a line, but the paper model is not perfectly round...
2009-10-25 06:30 PM
Ralph wrote:I think the shapes I drew should work when it comes to multiplying and rotating them, but I can soon alter if, if it doesn't look right.NStocks wrote:Using the attached image:
Do you think I should make all the edged more round and parallel to each other i.e top to bottom join intersect if you were to join a line, but the paper model is not perfectly round...As for the polygon shape, it's really up to you. I can email the shapes I drew, but they were just eye-balled and probably didn't clean up the way you intended.
- 1) Join two polygons by selecting one, clicking on one of the vertex nodes, selecting the 'Add to Polygon' method from the pet palette, and space-clicking on the second polygon (hold down the space bar and click on an edge).
2) You make a hole in a polygon by selecting it, activating the tool it was drawn with, and drawing the shape of the hole you want inside the selected polygon. For a circle, it is easier to draw a circle for the hole first (with the circle tool), select the polygon, turn on the tool it was drawn with, and space-click on the circle.
2009-10-25 07:55 PM
2009-10-26 01:29 PM
NStocks wrote:The
When I try to bend the plan, it keeps saying: Screenshot.
2009-10-26 03:04 PM
2009-10-26 09:18 PM
2009-10-26 11:41 PM
NStocks wrote:Each successive object encloses the previous one, so logically it must have a slightly greater radius and therefore must be a slightly longer profile. In my first example, I made them all the same size and consequently you can see where they clash rather than overlap.
Do you think I will need to alter each piece so that they intersect at the same point I.e the hold at each end.
NStocks wrote:What happens when you manually enter a bending offset into the object settings? If that doesn't seem to be having any effect, send the object you've made by PM and I'll take a look at it for you.
it still won't let me do it. I've even drawn a different shape to see if that makes a difference
