I can't change floor plan display option for all objects
I want to change my door, window and other elements floor plan display options, but when I click other options, it just changed the name for it rather than making the real change. So when you deselect and select the object again, it comes backs with the same floor plan display option(most of time, it is symbolic) Seems like it is a real bug for me.
Hi there,
I think you may of run into a known bug, in which on Mac's latest OS X - El Capitan, drop down menus of not just floor plan and section but any drop down menu would not work correctly. This bug was fixed in the latest update for AC18 Build 7007 and AC19 Build 4011.
You can check for updates within ARCHICAD by navigating to the Help Menu>Check for updates.
Or download the updates manually via the links below:
AC18 Build 9019
http://www.graphisoft.com/downloads/archicad/updates/AC18/AC18-9013to9019-ReleaseNotes.html
AC19 Build 6006
http://www.graphisoft.com/downloads/archicad/updates/AC19/AC19-5005to6006-ReleaseNotes.html
You can read more about this issue on the following Helpcentre article:
http://helpcenter.graphisoft.com/technotes/operating-systems/mac-os-x-10-11-el-capitan-beta/#Can8217...
Let me know the results!
Marcus
