2024-10-09
05:39 AM
- last edited on
2024-10-13
01:30 AM
by
2024-10-09 06:34 AM
We need more information.
What are you trying to change?
Can you show us the settings?
Also it is better to use a screen capture tool and paste the image in your reply rather than taking photos of the screen.
2024-10-09 05:24 PM
Okk. I gave my stairs a 5’ wide measure, but as you can see, the stair doesn’t measure 5’. On the floor plant it shows that is 5’, but in the 3D it’s not.
2024-10-10
01:10 AM
- last edited on
2024-10-13
01:31 AM
by
2024-10-10 02:55 AM
I tried to replicate your settings and had no trouble (I am not used to suing Imperial measurements).
I can see the outline of your stair is there, but I do not know why it is cut in half and the treads and risers are not showing.
I would try a new stair, select from the favourites a basic concrete stair to reset all of the default settings.
(See how a screen capture image is so much nicer that a photo of the screen?).
2024-10-10 03:45 AM
"Start + Shift + S" to screen clip.
| AC22-29 AUS 3200 | Help Those Help You - Add a Signature |
| Self-taught, bend it till it breaks | Creating a Thread |
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 7800X3D | 32GB | RTX5070TI |
2024-10-10 09:37 AM
Hi Denis,
Do you have "3D cutting" on with a vertical cut plane set to the stair axis ?
Just turn it off.
