I lost the element info palette...
I forgot where I can find the little window showing information (area, length, volume etc) for a selected element in the 3D view. I know I had it a couple of months ago bur now I can't find it....grrrrrrrrrrrrrrr. Please help me find it.
/Mats
5 REPLIES 5
Ben Odonnell
Mats.
You can find it under, Window/Floating pallets/Show element info.
HTH
Cheers.
Ben
Ben O'Donnell
Architect and CTO at BIMobject®
Get your BIM objects from bimobject.com
Ben wrote:
Mats.
HTH
Cheers.
Ben
That's were I thought it would be but the palette didn't show up on my screen...I suspect I have accidently moved it out of screen so to say...I will try to find it. Otherwise you can show me on tuesday!?
Mats
Ben Odonnell
Hi Mats.
No problem at all I can show you on Tuesday. But if you can't wait until then, you can try increasing you screen resolution to 1600X1200, if you are not already using it, see if you can find it then.
HTH.
Cheers.
Ben
Ben O'Donnell
Eduardo Rolon
Just do a new and reset
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
another Moderator
Ben Odonnell
Why?
If you do a New and Reset, if you have customized your interface, it's going to take you more time to reorganize your tool boxes than it would just to change your resolution. Ok I can understand if after changing your resolution if you still couldn't find it: But otherwise I'd wait.
Ben O'Donnell
