I need help with stairs option
I am using archicad 14 and i want to use the L shape stair but i want the long part to be going up point (fisrt floor) and the short part to be the end point (second floor) is that possible? please help
3 Replies 3
There should be a setting for the number of risers/treads in each flight.
NCornia
Graphisoft Alumni
Graphisoft Alumni
In Parameters dialogue of the stair objects set "Parameter Type" to "No. of Risers per Run" and then below you are allowed to set these numbers (grayed out if "Tread Height" option selected).
Nicholas Cornia
Technical Support Team - GRAPHISOFT North America
ARCHICAD on Twitter
Tutorials
GRAPHISOFT Help Center
Oh THXXX alottt :DDD
