IFC Export, Building Material Not Found
I get a ton of these messages when exporting to IFC
I don't see a way to identify which building material it's talking about?
Building Material not found
at line 6 in the 3D script of file Tread 21.gsm. (TREAD-061)
at line 6 in the 3D script of file Tread 21.gsm. (TREAD-066)
at line 6 in the 3D script of file Tread 21.gsm. (TREAD-063)
at line 6 in the 3D script of file Tread 21.gsm. (TREAD-062)
at line 6 in the 3D script of file Tread 21.gsm. (TREAD-064)
at line 6 in the 3D script of file Tread 21.gsm. (TREAD-065)
at line 85 in the 3D script of file basicStairTread_m.gsm. (TREAD-062)
at line 85 in the 3D script of file basicStairTread_m.gsm. (TREAD-064)
7 REPLIES 7
Did you check all your composite structure ?
Perhaps there are missing materials ?
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
OS 13 Ventura - MacBook Pro M2 max- 32Go RAM
You mean check all 1 hundred?
Look at the tread settings in your stairs.
I think you will find the material is missing.
Sure that's probably one, but I got several hundred lines here. Are there no links to the actual objects?
You can probably try to create a schedule about your model elements to find more easier the good one
Christophe - FRANCE
Not sure I understand what that means?
"a schedule about your model elements"
That will reveal it?
I think it's a great beginning to reveal your right elements and after their materials
I often use schedule to check my models
Perhaps it will limit the number of composite structures to check
Christophe - FRANCE
