IFC export Error
TTemples
When publishing to IFC, the following error pops up. How do I locate the reversed elements?
1 REPLY 1
The elements should appear pink (magenta) in your 3D model and in plan.
You can also use find and select to search for element types that can be linked (wall, column) and have an 'inverted height' that is true.
