Imported external drawings are invisible!
When I import an external drawing in v10, which I've done successfully hundreds of times, the imported drawing appears as an empty box...in other words, the external drawing seems invisible. All that I see on the layout sheet is an empty box with a drawing title attached. Any suggestions?
9 REPLIES 9
What format is the imported drawing? DWG? PDF?
Thanks for responding. The imported drawing is also an ArchiCAD v10 file. We have some standard details, etc. that we simply import as external drawings instead of creating them as independent details. In the past, I've never had a problem bringing them in as external files.
You mean that you placed a View from another ArchiCAD file as a Drawing onto a Layout your own file?
Check what happens if you select the Drawing and right-click on it, is there a"Open external source View" command or something similar. Then use it to open it, probably in another ArchiCAD copy to see what that View stores. Just want to check that the View settings are correct in the other file so there is stuff to show up in the Drawing on the Layout.
Yes, I brought in an external view. Nothing happens when I right click on the drawing. View settings haven't changed and seem to be correct. I've tried bringing in this same view into other layouts, but the same thing happens...the view is completely empty.
It is kind of hard not seeing the file.
Maybe there is something with the Drawing Settings that causes this.
If you create a New Project based on the Template file and you place that external View on a Layout, does the same problem occur?
Yes, the exact same problem happens. Very frustrating.
I wonder if it is related to either the drawing frame or the pen set associated with the drawing? Perhaps the drawing is there, but outside of the frame.
Did you try opening Drawing Settings for one of these external drawings and under the Frame panel, verifying that "Fit Frame to drawing" is selected?
Same dialog, under Properties, if the scale is right, is the Pen Set one which would have non-white pens for the drawing elements?
AC 28 USA and earlier   •   macOS Sequoia 15.4, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Drawing still isn't there. Checked drawing settings, just to make sure all settings were correct. Perhaps this external drawing file became corrupt somehow. We've had problems, actually much worse, with other files lately, where all fonts convert automatically to an alternate font and where all layer sets are dismantled (EVERYTHING falls onto one layer). We've used ArchiCAD for 11 years and have never experienced any of these problems until two months ago.
Does the same problem happen when you place the View on a Layout in the same file the View is located, not in another file?
