Importing Master layouts
Richard Swann
Does anyone know a (painless) way of importing masters from one AC file to another in AC10 or 11?
The 'external content' does not identify a master as a drawing in its own right.
Richard Swann
MacOS 11.7 , Intel Imac 4k ArchiCAD 4.5-27 (Solo)
You'll need to bring up your organizer palette. The button in the top left corner will allow you to open another project. This will let you see one project on the left and your current on the right. Then all you need to do is drag the master from the left side to the right side.
Richard Swann
Fantastic, thanks, I knew there had to be an easy way.
Richard Swann
