‎2010-07-15
07:36 PM
‎2023-05-25
05:06 PM
Rubia Torres
‎2010-07-15 07:48 PM
‎2010-07-15 08:13 PM
‎2010-07-15 09:48 PM
Archimamamia wrote:No not directly. Ask your surveyor to provide point file for the survey. Typically this will come as a .txt file listing the xyz coordinates of the measured point of the survey.
I read that about text file, my question is: can I, change the dwg file received into a "txt" file?
‎2010-07-19 03:33 PM
‎2010-07-26 03:15 PM
‎2010-07-26 04:55 PM
‎2010-07-30 09:01 PM
‎2010-07-31 01:12 PM
ares997 wrote:
I just am curious if the contours are represented in 2d and/or if there is a method for representing that data in 2d some how?
‎2010-07-31 04:45 PM
ares997:
There is a method described in this thread, but the contours are straight line segments at each mesh plane, not curving contour lines:
Getting contour lines from a mesh
David
R wrote:So here it is, almost 1 year after this old thread....
Thanks for the tips, guys.
I used a vertical stack of slabs to generate the contour lines, with SEO to automatically update them as the mesh changes. This generates all 16 contour lines in one step. It allows me to concentrate on the high points, valleys, and various spot elevations that I want to see on the site, and let the contours draw themselves.
