‎2007-03-06
05:26 PM
‎2023-05-23
03:20 PM
Rubia Torres
‎2008-09-02 02:04 AM
Brett wrote:You could also simply place a horizontal 'wall' object, and use OBJECTiVE's Split tool to cut it to the required slope:
You have a wall, the top two corners (or just one) have a hot spot on it to adjust that height of that point of the wall up and down to adjust the angle of the top.
‎2008-09-02 02:40 AM
‎2008-09-02 11:25 AM
Brett wrote:This feature could be implemented as a 3D hotspot that is dragged to the required level, but it's sometimes difficult to implement a hotspot in a way that makes its purpose clear, doesn't conflict with another hotspot, and doesn't clutter the 3D display. And when it comes down to the details, it is often essential to work in a section view.
Objective does about every thing else, so hopefully it can do this somehow. Or is it that AC will never be able to do this with any walls,not even Objective.
Brett wrote:Yes, your registration code will work with all versions of OBJECTiVE for both Mac and Windows. Once you've registered one version, the others will just work. The same features exist in all versions too, back to AC8.1 at present.
If you buy Objective now, you can download the Version for the AC you are using at the time and in the future, and all the features in the 12 version are in previous versions?
‎2008-09-02 07:37 PM
‎2008-09-02 07:49 PM
Djordje wrote:Yes - I tried to make that clear by writing
there is one very important point: What you create with Objective is an OBJECT, not a WALL.
