How to make window for angled wall
Hi, I have a problems when I want to make a window in angle wall, because my window can not match with the wall, the wall angle 105 degree (vertically), but my window still 90 degree, can you show me how to do that,,, thanks...
3 Replies 3
Try changing the opening plane to 'Associated with wall'.
Link
In AC12, the Window Opening Plane under the Preview and Positioning panel of the Window Tool will orient the window to the angle of the Opening Reference Plane as set in your Complex Profile.
That should give you enough info to find your way through the Reference Guide. Sorry, it's late here.
Link.
problems solved , Thanks guys....
