2004-11-0507:01 PM - last edited on 2023-05-2609:02 AM by Rubia Torres
Interesting Fill selection bug
2004-11-0507:01 PM
OK not THAT interesting... Try this: Select a fill with an area text. Now shift click the area text itself (as if you were adding the area text to the selection set). Both elements appear to be selected but as soon as you zoom in or out or do a redraw you see that the fill is no longer selected.
BTW am I the only one who wants area text to be applicable to ALL elements (slabs, roofs, poly walls)?
Nattering nabob of negativism 2023 MBP M2 Max 32GM. MaxOS-Current
Hi Chazz
This is not a bug but a feature.......
Turn off the Quick selection option and the fill will stay selected...
Sometimes!!!!!
You can have text applicable to all elements by using the label tool
Archicad 4.1 to 28 Tech Preview. Apple Silicon you can't build a line Mac Studio iPad Pro iPhone
