Learn more
Bruce
Interior Elevation - horizontal limit
Is there any way to set the horizontal range of an interior elevation (like you can with sections and elevations)?
Bruce Walker
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC27 5060 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
7 Replies 7
The Boundary you draw is the limit.
Bruce
Unfortunately that's not working for me. My interior elevations are showing elements far beyond where I've drawn the limit lines.
It's like they're set to 'infinite' display range...except I can't change it.
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
If you select such a problematic Interior Elevation line and go to its settings Dialog, in the Horizontal Range field, do you have it set to By Limit Lines or Add bounded area?
It should be set to the former.
Bruce
Yes, they are set to By Limit Lines.
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
Can you show a Floor Plan Detail, a Interior Elevation Settings Dialog and a generated Interior Elevation in screenshots?
Please also include AC version info.
This has been a problem with the internal elevation tool ever since it was introduced.
Here is an old related post.
http://archicad-talk.graphisoft.com/viewtopic.php?t=19799
That's why I have never bothered using it.
Another feature that is great 80% of the time and trouble for the other 20%.
Probably more 95% - 5% in reality but it is the times that it doesn't do what you want that make it not worth using.
I just stick to the standard section tool.
I might have another look at it again now in 14 just out of curiosity.
Bruce
Hmmm, wondering about that.
Normally I would do the same, but in this particular instance, keeping the project map structured and organised outweighs the disadvantage of this shortcoming.
Thanks for your input.
Cheers
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
