Interior Elevations - how best to adjust
rob2218
I need some help here folks.
Needing to add another "node" to the interior elevation marker.
when I do that...it transforms the tag into something very odd and unusable.
Please advise...see attached JPG.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
I believe what you want to do is have the "cut line" for that walls interior elevation moved back. See attached. Right now the view is cutting through the wall you want to see. Move the line back and it should do the trick.
By selecting the mid point of the 'elevation line' you can adjust the cut line in the same elevation.
Then to adjust the lines just select each part of the line and adjust.
See Example.
I apologize... I am not very technical.
rob2218
your answer, technical or not, was understood.
thank you Jenn.
i>u
Edgewater, FL!
SOFTWARE VERSION:
