Intersection Priority for Three Walls
I have three walls that meet in a point
There are lots of things to understand here, but we'll start with this and work our ways in;)
At 1), the intersection priority of the purple 905 and at 2), the intersection priority of the orange is 711.
Why doesn't the purple cut the orange here?;)
9 Replies 9
ok, seems I solved it;)
The composite had a reference point offset, for some odd reason
I don't understand why I see these lines here?
I looks like a very thin wall skin and it strength must be higher than the purple skin.
LucaP
Are those purple composite layers the same building material? If not then you will see these lines between these materials (even if you've duplicated material with the same cut fill).
Łukasz Pietraszko
ArchiCAD 28 PL, since AC20 | WIN 11 Pro
Intel Core i7-14700K 3.4 GHz | 64 GB RAM | NVIDIA GeForce RTX 4070 SUPER 12 GB | 2 TB SSD
Indeed, you are correct;)
Hehe, thanks
This gives me hope I will master this intersection priority some day;)
Now, it's correct;)
Hmm, no, I still see a black line here?
ok, think it was just misaligned;) Thanks
Now I see a black line here?;)
