Invisible tooltip
ratnabhirud
Is there any solution for resolution setting as I am not getting tool tip in tool setting dialog box as attached image even screen resolution for my comp is 1152 x 864 ?
Thanks & Regards,
Ratna
AMD Ryzen 5 3600 6-Core Processor 3.59 GHz
Ram - 16.0 GB
System - Windows 10 Ultimate, 64 bit
NVEDIA GForce 8400GS
Archicad 9..., 24
1 REPLY 1
NCornia
Graphisoft Alumni
Graphisoft Alumni
Ratna,
Yes this is specific to Windows. Here is an article on the fix: http://archicadwiki.com/Bugs/MissingTooltips
Best regards,
Nicholas Cornia
Technical Support Team - GRAPHISOFT North America
ARCHICAD on Twitter
Tutorials
GRAPHISOFT Help Center
