Is 2 separate railings and one set of stairs possible?
Archicad Version: 9
Is it possible to create a new set of stairs where there are railings either side, but different designs? Since one side is against a concrete wall, I'm looking for a simple hand rail fixed to the wall, and the other side is open, thus would require railings attached to the stairs.
SuJey
2 REPLIES 2
__archiben
it is, but the designs are pretty limited. under the stair's parameters pane, choose your right and left railing types from the drop-down menus. i.e. for the 'left rail' switch to something other than "same as right".
HTH
~/archiben
b e n _ f r o s t
Aussie John
hard enough to get the handrail you want let alone two of them
Cheers John
[/size]
